Showing results for tags 'import coordinate'.
    • import coordinate ×
  1. Hi, I'd like to modify this lisp to insert survey points as block showing only point number (2D or 3D, doesn't matter), and I'm having trouble figuring it out. Point file is in format: "Point number","East","North","Elevation" I'm attaching ex. files. I'd be thankful for any help. Points.txt...
  2. Hello guys, I'm trying to make a lisp to import points from txt file to autocad, and then to polyline them and to make a union from those points, creating a iregular area. The main purpose is to calculate the area of this created object. The txt file is something like this: 101 234.442 442.42...
  3. I have used GeoBuilder's LISP routine to import points coordinates into CAD. Apparently it is done but I can't see the points. How can I make them visible? Also I expect after clicking OK, a line connecting the point, appears but nothing happens. ACAD only construct the layers. How can I make...
