Showing results for tags 'imperial conversion'.
  1. Hey hi all, maybe i should poke a stick in my eye because the answer is looking at me. I'll bet but heres my first question... I have created a project in a metric template, then found that the scale factor is haywire. Is there some way to rest the template with out loosing my work or changing anything other than the physical line properties? Second, I have loaded the same file onto another students file who's scale factor is A OK and metric. My file LOOKS fine but when i start to add lines or dimension all the properties are imperial! Thanks for reading, gejay.
