Showing results for tags 'image frame'.
    • image frame ×
  1. Using AutoCAD 2016, when I pick a point inside an area to HATCH, the frames of images attached to the drawing create boundaries for the hatch, even when the images are not visible and the image frame variable is turned off. How can I avoid this? Thanks.
