Showing results for tags 'if function'.
    • if function ×
  1. Hi, I want to check for the width and height of a Rectangle. I got this code (defun getRect () (if (setq rec (ssget "_X" (list '(0 . "LWPOLYLINE") '(8 . "LAYOUT") '(90 . 4) (cons 410 (getvar "ctab")) ))) (progn (setq e (ssname rec 0))...
  2. Hi, I'm trying to query the variable "Weight" and if it has the content "50" I want to define a new variable: "Stamp" with the content "internal". Is WCMATCH the right command for this? (if (= wcmatch Weight "50") (progn (setq stamp "intern"))) (princ)
  3. (defun gp:getPointInput (/ StartPt EndPt HalfWidth) (if (setq StartPt (getpoint "\nStart point of path: ")) (if (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")) T ) ) ) ) I thought the syntax for the if function wa...
