Showing results for tags 'help with lisp'.
Prewritten Lisps and Acad Commands Combined for .dxf Import
KraZeyMike posted a topic in AutoLISP, Visual LISP & DCL
Almost every drawing I work on is exported from another Survey program and then Imported into Civil3D as a DXF I have sped up this process with a Lisp command and built in AutoCAD functions but would really like to combine the whole process into one Command. I am not sure if I can modify and com...- 6 replies
- help
- help with lisp
I found this lisp on this forum, and it is almost perfect for my use case. The one thing i would like it changed about it is that instead of asking for my input for a color, it changes it for a certain one that we set in the code. The thing i would like this code to do: after entering t...
Hi all, I came across a LISP routine that freezes the layer of any selected object. It works great but I want it to viewport freeze layers, not freeze for the entire drawing. This is where I found it: http://forums.augi.com/showthread.php?78426-Special-Layer-Freeze-LISP-Routine and this...
- lisp
- help with lisp
Hello CADians , I couldn't find a solution to this problem anywhere online. I am also essentially a newbie when it comes to AutoLISP as I have only learned the language ad-hoc to meet certain needs of my business. I have a lisp routine that reads a text file, each line has coordinates depths...
- 5 replies
- help with lisp
- atof
Hello, I am new in coding lisp files. I worked with vb.net so this is very strange for me at this moment . I want to to select two points with different coordinates and to calculate difference between Z. I want to label that difference and to draw line with specific length under text. I did some...
- 15 replies
- length
- help with lisp
Lisp to draw circles and rectangles from values in a .CSV file
CADINATOR posted a topic in AutoLISP, Visual LISP & DCL
Hi, brand new to this site and my very first thread! I am trying to write a LISP routine and basically have no experience with it except for opening them up and trying to decode it for my self. I am going over lisp basics right now but thought I would through this out there in hopes of learning some...- 9 replies
- lisp
- help with lisp
First of all, congrats on this nice forum and was i can tell a nice community. I need some help with a lisp code, because i can understand some of the code but in reality im a copy e paste "coder" ... The code im sending its a compilation of some free lips i found and i tweak it to fit my ow...
I am in a hurry with the project so I don't have time to write this lisp myself specially couse I don't have any experience in it, so if anyone can help that would be great. Anyway I have a lot of parcels drawn in autocad and what i need to do is trim all the polyline endings and intersections and i...
- 28 replies
- lisp
- help with lisp
ok, so there's not 5 strcats, but i thought the title was catchy. so i've been making this NEW autolisp based off one i made last week of other people's code i cobbled together and personalized. everything works EXCEPT the little equation i put in. here is the working code BEFORE i updated...
- 5 replies
- help with lisp
- equations in lisp
