Showing results for tags 'help wanted'.
    • help wanted ×
Found 14 results
  1. Almost every drawing I work on is exported from another Survey program and then Imported into Civil3D as a DXF I have sped up this process with a Lisp command and built in AutoCAD functions but would really like to combine the whole process into one Command. I am not sure if I can modify and com...
  2. Pizza! My block is a simple arc that can be swept around a circle and retain an enclosed area, like an adjustable piece of pizza. It works fine as long as I drag the grip, and mostly the input works too but there are certain sequences that mess it up, going past 180° mainly. Drag it to 90°, then...
  3. Im interning for a medium sized company and I was tasked with creating a new file structure and naming system for our engineering files. I was wondering what are the best ways to name CAD files so that they are easy to find and make sense. Thanks you all your help guys. I really need it. Also we use...
  4. Hi this is my first autocad 3d project so forgive me if I am not using the right terminology. So I need to create a boxed shape cover for an instrument that we have. So I drew the base in 2d then used the extrude command to build the box, after that I used the shell commands to empty it, now I a...
  5. This is my first ever attempt at learning AutoCAD and I'm having some issues. After I've chosen the starting points for a line, a box shows up and I'm not able to access the command line unless I enter something into it. E.G. 12, As soon as I hit that comma the box disappears until I plot my n...
  6. Hello, I'm very new to Autolisp, and I am having some trouble with my code. Here's a description of what I am trying to do: I have a drawing consisting of two pipes, bottom pipe and upper pipe. They will be inclined in reference to the paper, represented by the square. I need to insert at th...
  7. obscurejack
    Rhino issue: solid modeling
    Hello! I'm a noob in rhino and I found some problems by making a polysurface solid: my problem is that I have two elements: a sphere and a twisted pyramid, joined by boolean union which I can't offset to add an internal thicken. when I do it (with "solid" option activated) it just creates a polys...
  8. Hello everyone, I'm having some some issues with a sheet metal part I'm working on. Im very new to the inventor software, but can work thru most thing i come across. Our issue: We are designing a chute to fit around an inclined conveyor inside of a tank. I have made the sheet metal part by loft...
  9. I haven't used Inventor in about 4 years, and I tried to create a project in Inventor using the 2013 version, but once I created a project file a bunch of the original settings got messed up. I now can't open a drawing, assembly, or presentation from the home window that pops up. I can only use the...
  10. Hi guys, I'm new here and in programming also. I need to create a programm which should check a drawing. The check means, that we have 3 different layers: contour, axes and section. As you know all of them must have different lines thickness. So, let's imagine that thickness should be: 0,5mm 1m...
  11. :cry:I use to work for a firm that taught me AutoCAD, I have since left and invested in 2013 version. When we plotted our drawings the line weights (especially on Elevations) showed great dimension. I have played around to death and just cant get a good CTB file created...... Could anyone share or s...
  12. So, to give some background information, I have 0 experience with LISP programming, and am an intern at an engineering company. I really would love to score "brownie points" by automating an extremely boring and time consuming task. I have experience with other languages, and can work off of a good...
  13. Hello here! I'm new to AutoCAD (mechanical) but I've seen some intro video's (getting started video's) from AutoCAD and are very exiting to get started! Since I'm total new with AutoCAD, it's pretty challenging I must say! Let me give an example... From the picture attached, I want to make...
  14. I am currently trying to make a bracelet with text engraved in the outside of it with autocad, and my current problem is that I have to make the text 3D before I can subtract it from the bracelet. I am using autocad for mac, which means I dont have the express tools, most notably textexp. I am fairl...
