Showing results for tags 'help me'.
Hi I am trying to create a tartan/plaid design using hatch solid......overlapping stripes eg a yellow over a red = orange.........what are the steps so the colours merge.ie create the orange? any instructions would be appreciated
I'm working on a building a helmet, and I have completed a basic 3d model to help me visualize how I will build it. But I don't know how to flatten out a cone. the helm is made out of 5 pieces, a top, a top side piece and a bottom side(the sides are fabricated twice to make a full helm) I ha...
- 8 replies
- fabrication
- cone
Hello Guys Im new to sketchup and only played around with photoshop and GIMP so im new to 3D modelling and only been on the program for around 3 hours. As you may have guessed i'm still pretty bad having not had time to properly practice. Anyway I am looking to design 3 wolves heads in to a meta...
Help with changing a single number (attribute) in multiple blocks
MattJcooper posted a topic in AutoCAD General
Hi - New to auto cad & need help I'll explain as best i can. Version:AutoCAD Mechanical 2012. I have a number of CAD blocks i need to change an attribute in each of the blocks multiple times. The attribute DEVNAME - Varies* over multiple blocks. I need to change the number used in the a...- 1 reply
- multiple blocks
- help me
Help bending a loft inwards or create a whirlpool curve
redjoker81 posted a topic in Autodesk Inventor
i need help bending a loft inwards or create a whirlpool curve so i am trying to make the corner peice of a rubix cube 2.0 https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcS9uLEM_-bAVuVC78FZHS-69MjpuQGb3s00dup4GpjhhD13... https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcTjXyEHZp...- 2 replies
- help with assignment
- help me
Hey everyone, I guess this is a simple project but I have absolutely 0 ideas on how to do it. I know the basics of AutoCAD, but I'm not good at it. This is my assignment. This is the example of how my assignment should look like (keep in mind that it is not the final result of my assignmen...
How to get this LISP to add an additional 90 degrees to its rotate
msirois posted a topic in AutoLISP, Visual LISP & DCL
Hi there, You'll have to forgive my ignorance and I'm new to the whole LISP routine area. My work has this old LISP routine for rotating text which I modified to include MTEXT and blocks. I was hoping to change it solely for block rotation in another lisp routine. The way we have our blocks setu... -
Draw a Lot using Latitude and Longitude from Google Earth
Subiran posted a topic in AutoCAD Drawing Management & Output
Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth. Example: Point A. Latitude: 11 Degree 18'2.22"N Longitude: 124 Degree 57'46.89"E Please check my attachment picture.- 10 replies
- help me
- google earth
Im interning for a medium sized company and I was tasked with creating a new file structure and naming system for our engineering files. I was wondering what are the best ways to name CAD files so that they are easy to find and make sense. Thanks you all your help guys. I really need it. Also we use...
- 17 replies
- help me
- help wanted
Is it possible to customize the DIMJOGLINE symbol? The /\/ part that gets inserted is kind of spread out too much in my opinion, I'm wondering if there's a block somewhere hidden in the Autodesk folders that can be edited. After inserting this thing, I see no block in the drawing when I list the blo...
- 5 replies
- dimjogline
- dimensioning
Need to get LISP to plug Excel values into dynamic blocks
ergeebee posted a topic in AutoLISP, Visual LISP & DCL
I'm trying to get LISP to automate the editing of a bunch of dynamic blocks for basic things like width and depth. I want to have all these values set up by model numbers in in an Excel spreadsheet. In order to accomplish this, I've used the code for "Set Dynamic Property Value" by Lee Mac and "Ge... -
Hey everyone ... I need some help and I have noooo idea where to start or how to write the code needed to do my thought. I need a text file that gives a marker when you open and close a drawing w/ a time stamp and so i can track my day w/o trying to figure out how many hours I worked on a drawing....
We currently bought Building Design Suite from a re-seller and currently waiting on the product key for activation. We are trying to go ahead and download the suite. I have tried to go through Virtual Agent, but am consistently having problems. There's 4 parts to the download through the VA and only...
I work in the HVAC field. I've just around a year of experience with the program and have never had this problem before. I use 2 layers; 1 for piping and another for linears and dimensions, etc. For some reason, everything shows up on the model space, but once i plotted on the paper space, a good ch...
I need to change the attribute of "tag" = "PRO" in all blocks of the model space of the active document in autocad. The text you need to add is "my project". I searched for information about walking blocks and change the attributes but I get nothing. Can anyone help me please?
- 3 replies
- modify block attributes
- help me
Buying a Notebook to run Autocad 2015
Felix Carter - Shaw posted a topic in Hardware & Operating Systems
Hi Basic Info is that I'm wanting to buy a Lenovo s20 laptop with a; Intel® Celeron® Processor N2840 (2.16 GHz, 2.58 GHz with Burst, 1 MB cache) Ram 4 Gb Storage 320 Gb Im basically wondering will the processor run Autocad 2015 if not is there any small laptops (smaller the better... -
My friend is wanting to know the answers to these questions? 1a What is the advantage of creating a Block for use in an AutoCAD drawing? 1b Why is it recommended to draw Blocks on Layer 0? 2a What is the difference between a Block and a WBlock?...
Hello, I am semi-new to AutoCAD but have a fairly good knowledge of how to work the program now. However, I am continuously having problems with the presspull command. When I try to use the command on an object, the object is raised but not filled. It looks sort of like a fence/outline around the b...
- 38 replies
- 3d objects
- assignment
hello this is my first post here and it would be a question:) so we are working on this new project. and its kinda big project. my problem is that the drawing is so big it's a 32mb drawing and my computer is not responding or freezes every time i save, go to other lay out or even just panning. c...
I have a fully electrical drawing set complete with I/O from my PLC I want to generate a .xlm file. I then want to write a program that will scrape the file looking for I/O addresses, and then assign aliases based on the descriptions. I’m having trouble with the .xlm file. When I generate the f...
I haven't used Inventor in about 4 years, and I tried to create a project in Inventor using the 2013 version, but once I created a project file a bunch of the original settings got messed up. I now can't open a drawing, assembly, or presentation from the home window that pops up. I can only use the...
- 5 replies
- help me
- help wanted
This is my first time posting so I am not sure if this is in the right category. I am trying to create undefined ductwork in AutoCAD MEP 2013 with single line. Then convert it into double line using the Calculate Duct Sizes. It always converts my branches into Tee's with a 90 Degree Angle. Is there...
- 4 replies
- help me
- custom tee
May I get my Username changed? Curious if an administrator could be so kind to do this for me? I've been out of the game for awhile but I recently resumed my CAD career.
- 5 replies
- help me
- administrator
G'day, I have a stange inventor problem i am hoping some one can help me with. I am currently running Inventor Professional 2011. The problem occurs when attempting to create a section view, detail view, croping or any other type of view editing command in the .idw drawing. First of all...
Fellow Cadders, I've encountered a pretty nasty problem over the past week. I can no longer add specific layouts to existing sheet sets. I can make a new sheet set, but I cannot see the drawings that I would like to add to the sheet set. The only "solution" I've found is to make a new sheet...
