Showing results for tags 'help command'.
    • help command ×
  1. Hi, I have a Lisp that insert blocks, but some blocks requires a value to an attribute, and some not. So, I wrote the (command "INSERT" theBlock pt "" "" "" "") when the block requires a value attribute, its insert with nothing the last double quotes, but when the block doesn't requires a value the...
