Showing results for tags 'hatch pattern issues'.
I've been working on a project where I have used various hatch patterns to indicate sidewalks, bicycle paths and water. It shows up in my AutoCAD as shown on the screenshot, but the patterns are not appearing in either the print previews or the pdf's. Only one hatch pattern ends up showing up...
- 1 reply
- hatch
- hatch pattern
I am not able to create one simple custom hatch pattern.Please help !!!
sputhran92 posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
the dimensions are in millimeters Four lines to be used to create a line whose length is 1090mm I tried creating the pattern using a Draw Hatch 12.5 tool but I have been getting this 2 errors Bad pattern definition file: Missing parameter on line 2. ? Please if anyone can help me in...- 6 replies
- hatch dxf patterns
- hatch command
- (and 2 more)
I continue to get errors in my hatch patterns that I have found on the internet. I have one where the error said missing parameter in line 2 now it says missing parameter in line 3. other then reading the code there has to be a way to run these numbers through a program that could tell you what is w...
hatch pattern error, Missing parameter on line ***
squareknees posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
I hope I am posting this on the right forum. I keep getting kicked out of the webpage and I have written this post 3 times so hopefully I don't miss any information writing it again. I have an error in a hatch pattern and I have done everything I can think of to correct it. line 21618: 0,... -
error in hatch pattern "Missing parameter on line 21619"
I hope I am posting this on the correct forum. I am having an issue with a custom hatch pattern. not one that I made. I found it on a website where you can share custom lisp routines and hatch patterns. I do not know how to create a hatch pattern. I am having an error with a certain line in the pat...- 1 reply
- hatch pattern issues
- error
... they look fine in my Model Space, but when I switch to Paper Space, those same light shades become Black. Then when I Plot, it's also Black How can I control this, and keep my Solid Hatches in the shades I need?
- 17 replies
- color
Custom Hatch Pattern Troubleshooting
dal-designs posted a topic in AutoCAD Drawing Management & Output
After spending waaaay too much time looking for a board and batten hatch pattern for vanilla ACAD, I found this in a Revit forum: *Board & Batten, 2.5" Batten at 16" o.c. ;%TYPE=MODEL 90, 0, 0, 16, 16, 16 90, 2.5, 0, 16, 16, 16 Doesn't work for vanilla ACAD, though. Since I don't kno...- 2 replies
- coding
Hatch Pattern Making ACAD Files Huge
dal-designs posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I found some hatch patterns from a stone supplier (Centurion or Eldorado; don't remember which now) that I really like and want to use. Problem is, using them makes the ACAD files huge- they routinely go from 1 MB without these manufacturer hatch patterns to 12+ MB with. Given that these patterns... -
Trouble with hatch patterns
Mark Richardson posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I'm using AutoCAD LT 2013 for Mac. I have searched other threads about loading new hatch patterns but haven't found an answer to my dilemma. Most seem to deal with locating the correct folder to place them in. I have done this correctly(or so I assume). The hatch patterns I downloaded (.pat fil...- 3 replies
- custom hatch pattern
- (and 2 more)
I want to create wall types based on certain assembly types with the true rather than nominal block and brick dimensions, and add them to the wall tool palette. How do I do this? Also, the hatch for a CMU wall is a 45-degree double line. Drafting standard I am accustomed to is single line perpend...
- 3 replies
- tool palette
Terrible Hatch pattern issues!
Elisabeth83 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I need to create a hatch pattern for a flooring tile that we have currently starting using and I am having real issues getting it to work!! The pattern is meant to be tiles set in a brick type style but with a rolling offset, but the tiles are different sizes - I have one row of 300x600, then a...
