Showing results for tags 'hatch dxf patterns'.
    • hatch dxf patterns ×
  1. the dimensions are in millimeters Four lines to be used to create a line whose length is 1090mm I tried creating the pattern using a Draw Hatch 12.5 tool but I have been getting this 2 errors Bad pattern definition file: Missing parameter on line 2. ? Please if anyone can help me in...
  2. Hello, I am trying to generate an ASCII DXF file with the Notepad++ editor. Following the next link: http://www.cadtutor.net/forum/showthread.php?6152-Help-with-Sample-code-to-Entmake-a-Hatch I wanted to draw a very simple hatched area. My problem is that no DXF viewer is able to draw anyth...
