Showing results for tags 'hatch boundries'.
    • hatch boundries ×
  1. I can't find how to recreate boundary of hatch using command line only. I can do it from hatchedit, but it requires hitting "recreate boundary" button in the hatch edit window. Any advice what command can be used to make hatchedit command line only? I found it! It's HATCHGENERATEBOUNDARY I c...
  2. Hello all, I am working in AutoCAD 2008 on a subdivision plan that has several sheet layouts. The roads in the subdivision are dimensioned and have a pavement hatch. In one of the layouts, however, we want to turn off the dimensions, but leave the hatching. When I freeze the dimensions in tha...
  3. I wish to hide my associative hatch boundaries. Is this possible to do as a permanent rule? I have seen that you can apparently put them on a different layer then turn them off. Does anyone have a quick trick for what i am trying to achieve? I used the selectsimliar command but it chose a...
