Showing results for tags 'hatch associativity'.
Hatch_Off.lsp - Script for HATCHING from existing hatch with no hatch dialog.
3dwannab posted a topic in AutoLISP, Visual LISP & DCL
Hi, Ever annoyed about having to open the hatch dialog to get inherent props from an existing hatch and then AutoCAD seems to think it fine for the hatch to be non associative too!!! Here is a script I wrote and wanted to share. It simply uses the addselected command to hatch your selected o...- 3 replies
- hatch
- addselected
How to Hide Hatch boundary?
cad_cow posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I wish to hide my associative hatch boundaries. Is this possible to do as a permanent rule? I have seen that you can apparently put them on a different layer then turn them off. Does anyone have a quick trick for what i am trying to achieve? I used the selectsimliar command but it chose a...- 12 replies
- hatch associativity
- frames
I want to remove all data labels from a drawing and I want hatches to fill the gaps. All hatches are created as associative fills. When I remove data labels using a Quick Select or Select Similar command only a few neighboring hatch areas are updated. As for the remaining gaps from labels pe...
