Showing results for tags 'google earth'.
I just wondering if you can give me some suggestion or any tutorial about showing underground piping (CAD) on the aerial image from google earth. this is for the presentation purposes to show an idea of project. Appreciate any suggestion.
- 8 replies
- aerial
- google earth
Draw a Lot using Coordinates from Google Earth
Subiran posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth. Example: Point A. Latitude: 11 Degree 18'2.22"N Longitude: 124 Degree 57'46.89"E Please check my attachment picture. -
Draw a Lot using Latitude and Longitude from Google Earth
Subiran posted a topic in AutoCAD Drawing Management & Output
Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth. Example: Point A. Latitude: 11 Degree 18'2.22"N Longitude: 124 Degree 57'46.89"E Please check my attachment picture.- 10 replies
- help me
- google earth
Subiran posted a topic in AutoCAD Beginners' Area
Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth. Example: Point A. Latitude: 11 Degree 18'2.22"N Longitude: 124 Degree 57'46.89"E Please check my attachment picture.- 3 replies
- google earth
- coordinates
I'm working in C3D 2012, w/the Publish to Google Earth functionality. I have managed to define object attribute fields and populate them with various C3D map tools. What I haven't managed to do is name the object. If I associate a number of fields to a polyline, the polyline will be listed in G...
I was wondering if anyone know any free or paid software like google earth that can snapshot real time picture of site plan. I want to big snapshot of an excavation site plan to get all the underground piping during the excavation. I don't think google earth able to get the real time picture. if a...
Currently working on some as-builts. Wondering if there is any program that will import gps coordinates from my handheld device and place them onto google maps images and then import that image with those gps waypoint into autocad. Thanks in advance
- 17 replies
- gps
- google maps
Hi I am a student and have very basic Revit experience. I have been given a Revit model and I would like to place it into Google Earth or equivalent for presentation purposes. Is this possible baring in mind I have a student Autodesk account and student version software? I would also like to...
- 2 replies
- maps
- google earth
Don't know why Autodesk decided to take away a nice feature but the 2013 version of Civil 3D does not have the import Google Earth image pull down window like the 2011 and 2012 versions had. Anyone know how to do this and keep the location of the image in the same coordinates as your drawing? The...
- 3 replies
- google earth
- civil 3d 2013
In Civil 3D, under the Insert tab, there is a menu selection that allows you to insert a Google Earth image directly from Google Earth. This image is inserted to match the coordinates of your ACAD drawing. However, it does not always match the known correct line work, depending on the drawing sett...
- 6 replies
- coordinate systems
- civil3d
Hi there, I am using Autocad LT 2013. I wish to use Autocad to draw subdivision lines and need to overlay satellite imagery (Google Earth or Google Maps) in tandem with Garmin GPS waypoints taken in the field. In the 'type a command' ribbon, when I type in 'GEOGRAPHICLOCATION' and select...
- 1 reply
- gps
- google earth
