hello everyone i actually have the above views and a full front section done but now that i have done that when i try to use solview to make a full right side section it uses my most previous viewport and i was wondering if any one knew a command for command prompt th switched the vieports that yoou can enter in the command prompt i do have a shortcut using control plus something so a way to use ctrl in script would be handy as well thank you for the help
