Showing results for tags 'floor plans'.
Creating an As Built Floor Plan Using a PDF File
indigo posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi Guys, I was asked to create an as built floor plan for a client..they sent me a pdf but it seems that the file is scanned causing the actual measurements to change..I'm not really familiar with some standards for doors..making it more difficult for me to construct the floor plan..I was planni... -
How can I do tracing in autocad? Suppose, I have two floor plans, ground floor and first floor in a single .dwg file. there are many layers with different colours. ground floor plan and first floor plan are sharing layers too. That is ground floor also has objects in the walls layer so does the...
- 19 replies
- floor plans
- autocad
Hello! My dad has given me floor plans in blueprint paper and he wants me to draw / copy them in AutoCAD. I've have learnt here that you should always draw 1:1 in model space and adjust the scale later on in paper space. My problem is that the floor plans are printed in a scale of 1:75 meters....
- 46 replies
- scale
- floor plans
