Showing results for tags 'flip parameter'.
    • flip parameter ×
Found 7 results
  1. Hi for everyone. I made a dynamic block for doors by combining some tricks learnt from other dynamic block. By the way thanks for the shared ideas. I am almost satisfied with the result but I still have two things to figure out.: 1. If the block is rotated by a rotate action and I enter a zero...
  2. Hello, I am trying to create a dynamic block that shows a spiral conveyor in several different configurations. I have text that needs to be able to be turned off and on. I had it working until I added a flip function. Now the text won't turn off and you have to select the "Angle" twice to get it to...
  3. i want my attribute to rotate from 90 to 270 using flip action. but when i added a flip action on my attribute, the action only works on newly inserted blocks. when i created as new text,mtext or attribute inside a block, any flip action doesnt work, and keeps its rotation. how can i make it work?he...
  4. Does anyone know a clean way to toggle a specified flip parameter using auto lisp visual lisp? I use the getdynprops, getdynpropvalue, putdynpropvalue [by Jeff Mishler based on code from Steve Doman, Herman Mayfarth and Tony Tanzillo] for most of my dynamic block changing needs but I can't get...
  5. I have a block with a flip action to move text from one side of the block to the other. We've revised the block and I'm using Insert/Redefine to update the drawings. The problem is, the flip action reverts to default and I have to flip them back. Is there a way I can lock the position of the...
  6. AutoCAD 2012 - 2D I'm trying to create an Annotative Dynamic Block (flip action) that contains a single attribute and some geometry.. The attribute is a "multi-line" attribute so it will change justification correctly when flipped. At the moment I would prefer a "single-line" attribute caus...
  7. I have the application attached below with these problems: 1. The flip action works fine on (1 to 1) but for the rest it's a mess. 2. The Length is not updating instantly I must regen. I want it to update automatically without regenerating the file Thank you Dynamic Lanes.dwg
