Showing results for tags 'flat pattern'.
automation How to create random but "inline" stipple line or hatch pattern
pseudoclay posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Good Day AllI've turned to forum advice and I really hope someone can help me.I have to create 13 wall panels that will be laser cut. The panel drawings were done in Inventor and I'm editing the flat pattern in AutoCAD. If you look at the attached images of one of these panels you will get the idea,...- 3 replies
- autocad
- flat pattern
In Inventor, I wish to model a piece of metal. I wish to create a loft between two (2) sketches, and then unfold the item. I am having trouble and I need some assistance. Even though my sketch geometry had correct material thickness and bend radius, consistent with the sheet...
cone development Autocad Dynamic Block of Cone Development
jamildear4u posted a topic in Blocks, Images, Models & Materials
I have shared a Dynamic Block and you can download through the link below and also can watch video that demonstrate it how to use 2D dynamic block to develop a flat pattern of a cone that has been oblique Section. I hope you will subscribe and Like my video/channel. Thanks Down...-
- 3
- development
- flat pattern
Problem Making Sheet Metal Flat Pettern in Inventor 2010
foxthegreat posted a topic in Autodesk Inventor
I am having trouble making a flat pattern from a sheet metal part. I can make a flat pattern from portions of the part, but not the entire thing. Is multiple bends in different directions too much for Inventor to handle or am I doing something wrong? Thanks for the help! -
Hi, This should (on the face of it, parden the pun) be an easy task. I created a lofted surface over 3 scketched lines. The result is a niceCAD Tutor.zip curved surface. I then thinkened the surface and converted to Sheet metal. At this point I expected to just set the sheet metal defaults to the s...
- 3 replies
- surface
- flat pattern
