Showing results for tags 'find text'.
Find for text and display it in the center of the window
teknomatika posted a topic in AutoLISP, Visual LISP & DCL
Hi, I ask for your help for the following. I need to find a particular text string among thousands. Once found, it should be centrally visible in the window. I can't do that in the tool "Find and replace" because when I leave it, the location is lost. Another alternative would be to draw a... -
Hello all. Kindly find attached drawing which shows simple reinforcement schedule. I have a problem with Texts which are shown in yellow color.When I click on one of them - for example 1∅16 L=1175 , at the properties area, I see text Contents 1%%O%%C%%O16. When I try to find 1∅16 I can't fin...
Hi all, I'm looking for a way to check my BOM lines (mostly copied from multiple drawings) for duplicate part numbers (all number, no alphabets but might have - or _) in an attribute block with a tag named DESCRIPTION & SAPNUMBERS. Example If the description says 12345 in one line and if...
