Showing results for tags 'find and replace'.
    • find and replace ×
Found 5 results
  1. Hi, I ask for your help for the following. I need to find a particular text string among thousands. Once found, it should be centrally visible in the window. I can't do that in the tool "Find and replace" because when I leave it, the location is lost. Another alternative would be to draw a...
  2. Hey all, I am trying to change some text in my cad file, but when I try to use the wild card in my search, nothing shows up. (attached screenshots are an example of what I'm seeing) Any insight into this would be greatly appreciated. Thanks,...
  3. ok, i'm sorry if this has been asked before but i couldn't find it. I recently moved from autocad 2008 to 2012. my machine intel Xeon E5-1603 @ 2.8GHz 32GB mem win 7 64bit dual V4900 AMD vid cards autocad 2012 so my issue is this (and i have only found one other person asking about th...
  4. I'm trying to find a lisp routine that searches the current drawing for a certain string and replaces that with the string of a variable already defined by the user (in this case the text to look for is "****" and the variable is called "offerte"). Not only in the Text, Mtext but also in the Blocks...
  5. Hello I am trying to make multiple find and replace all the texts (text, mtext, and texts in blocks etc) in model space through excel vba (and not through Autocad vba). I got the basic code from here and trying to modify for my requirements. http://forums.autodesk.com/t5/Visual-Basic-Customiza...
