Showing results for tags 'fillet command problem'.
Filllet & Chamfer Problem
Mancelp posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Fillet and chamfer quit working properly. When I try to join 2 lines that are perpendicular nothing happens. The texts on the command line are what they always were with no error messages and ends up with the usual "Command:" after I am done. If I put a distance into the chamfer command it wi... -
How can I choose where to put the fillet arc on AutoCAD?
fsolis94 posted a topic in AutoCAD Beginners' Area
I am trying to draw a detailed representation of an extension spring. Right now I have two slanted parallel lines and I want to connect them using fillet, but I do not want the arc to make these lines longer, I want the arc to be above the line they intersect with, something like this \__\ How do... -
Strange problem in FILLET command in AutoCAD 2011
archash posted a topic in AutoCAD Bugs, Error Messages & Quirks
Sometimes In AutoCAD 2011, when i fillet two lines very close to each others with radius 0, the first line move closer to the second line instead of extending them in the same direction! Can anyone help?
