Showing results for tags 'fillet 3d edges'.
    • fillet 3d edges ×
Found 4 results
  1. I'm trying to fillet all of the edges of the winding extrusions on this part. I've circled one section that partially filleted, with the exception of the narrow curve. When I try to do other areas this error comes up: Modeling Operation Error: Could not find acceptable sequence of capping...
  2. guitarpirate
    Large fillet won't work
    Hello, I have a part with an arc'd side profile, and an extrusion that goes from one edge to roughly middle of the ark. Next step is a smooth transition between the profile and the top of the extrusion. Inventor is letting me do a .5mm fillet but no larger because of "complex geometry". I don...
  3. Hi everyone, last time I used AutoCad was back in 2009, and I am having trouble remembering/ finding a few things in my 2011 version; I could use your help please. First I am still editing my 3D objects in the 2d workspace, how do I switch to the 3D workspace (with the white background)? Also, I mad...
  4. I would like to fillet a box, which has already been filleted, with a radius of 3, but cannot seem to get it working. Can anybody please advise? See attached. I am currently running acad 2009. Thanks in advance. cellphone.dwg
