Showing results for tags 'file size increase'.
When I paste from one file to the next my file dobble in size
SofieAske posted a topic in AutoCAD General
I'm having a lot of problems with a set of drawings that are getting bigger and bigger. When I started working on them they where about 800kb - with no mayor changes the file has grown to 13000kb. They problem starts when I paste from one file into the next - even though is just one block or one lin... -
Hatch Pattern Making ACAD Files Huge
dal-designs posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I found some hatch patterns from a stone supplier (Centurion or Eldorado; don't remember which now) that I really like and want to use. Problem is, using them makes the ACAD files huge- they routinely go from 1 MB without these manufacturer hatch patterns to 12+ MB with. Given that these patterns... -
Hi, I have this 3d file of mine (which i have worked so hard for it), and it's size has increased to 240 Mb's! I assume this has happened due to forced closings and the backup files ... i have already deleted them... but it didn't help. i ant even copy my model into a new work space. please... h...
- 8 replies
- file size
- autocad 2013
Dynamic block increasing file size
mrdjezmin posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi everyone. I'm new to this forum and this is my first thread. So here goes: I've developed a dynamic block for a standard bulb flat profile cross section using parametric constraints to alter the sizes of the profile. I also made six visibility states for altering the penetration type of the pr... -
crashes others computers after emailing dwg
pneal231 posted a topic in AutoCAD Bugs, Error Messages & Quirks
I am a contractor that does work for several different companies. When these companies send me their dwg file I have no problem opening them up to edit them, but once I complete my edits and email the file back to them they are telling me that their autocad crashes while trying to open the drawing o...- 46 replies
- file size increase
