Showing results for tags 'file name'.
Get part of dwg file name and write it on a inside attribute block.
CafeJr posted a topic in AutoLISP, Visual LISP & DCL
Hello Guys, I have a doubt, someone knows if has some Lisp to get the last digits (specified - user input) of a dwg file name (in Windows explorer) and write it on a specific attribute name on a internal block. Eg.: I have a folder with 600 pages dwg files, so, the last numbers of it is a s... -
Hallo, Im working in AutoCad Map 3D 2012 under Windows 10. I have a problem with visiniti of the name file (and drawing path). It is visible only in with reduced window, in fullscreen regime it is invisible (the title bar is white). Thank you for help. Adam Examples: reduced wind...
Error message of Invalid Characters in File Name (AutoCAD LT2007)
Bud McK posted a topic in AutoCAD Bugs, Error Messages & Quirks
For years I have named files using a hyphen, ie 12-3456-1 REV 0.dwg, but today I am not able to open or save files containing the hyphen. Get an error message of "invalid character in file name". I've renamed such a file with the hyphen removed and it could be opened, but not "saved as" with the d...- 3 replies
- file name characters
- file name
