Showing results for tags 'fatal error'.
    • fatal error ×
Found 10 results
  1. I'm running AutoCAD 2012 on Windows 7 and my eTransmit has stopped working in certain instances. If I use it through a sheet set it usually works fine but if I use it in a drawing it won't grab the xrefs. When I try to click the Transmittal Setups... button it causes a fatal error like the one i...
  2. Dear all; Why this happens!!! I had open a file (size 37MB), it is almost purged I just purge 4 nos. of layer, 3 blocks, 1 line type & 9 registered applications deleted. Now save, the file size become 80MB I am using AutoCAD 2013 (Pirated software, which downloaded from some torrent website...
  3. We have an ongoing problem running AutocadLT2015 with Xrefs causing fatal errors accross a few computers in our office. What happens is: Error occurs after deploying an existing acad dwg into the 2015 file (which saves as 2013). Select Xref, Clip Xref, and then rotate Xreflaunches the...
  4. I'm new at the forum and have to get a drawing out the door. I am a surveyor. Here's what I have, It just started. When I go to import points, then click the folder for the destination of the .txt or ascii file it gives me a fatal error. Never had this happen. I did open up another drawing...
  5. btraemoore
    Fatal reading error...
    I'm accessing autocad via COM and netloading a custom dll, but when i call my start function inside of my dll, intermittently i get a fatal error.. I do not get it when i call the method from in process, but only when i call it from COM. Here is the code from when get a list of paths. pri...
  6. Hi, I just switched over to a 64-bit computer. I'm using AutoCAD 2004 and windows 7. I never had problems with FATAL ERROR crashes with my old 32-bit computer. However now when I open the same files that I used to open on my last computer I'm getting a lot of FATAL ERROR messages that I never...
  7. Hi, this is my first time on the forum. I am currently a student at the University of Cincinnati - College Conservatory of Music and am running AutoCAD 2012 Educational on a Boot-Camped iMac. I draft in 3D for shows and classes and the program gives me a fatal error window and crashes all the time....
  8. 19cruthik68
    fatal error!!!!!!!
    Who can help me with this problem? I saved my 3d drawing and close it and then when i tried to re-open it i've got that message. what's the problem with this? how can i recover my drawing?is there a way. i tried also to open it in other desktop who has an autocad app, but then same thing happens.pl...
  9. I had the free student version of autocad 2012, and it worked fine for a couple of months. Then a couple of days ago, I suddenly could not open the program. I did not try to open a specific file, just the autocad program itself. It showed me this error message: fatal error unhandled e0434352h E...
  10. Has anybody experience any problems with this before? The problem being that we are running a number of long term contracts and therefore it is easier to use the same CAD version throughout the length of the project. Thats is fine with us, but now somebody, in their wisdom has opened one of the cent...
