Showing results for tags 'external reference'.
    • external reference ×
Found 4 results
  1. Has anyone experience this or know why this happens? dwg A is x-refed to dwg B. am working on dwg B & click on x-ref and go into Edit reference in place. if I now click on > any object and go into properties & change the color from bylayer to red (for example) and save changes. -every...
  2. Hello, I had to update some drawings from AutoCAD 2007 and each of these drawings has at least 7 XRef files attached to it. Each of these files have about the same number of XRef files attached to them as well. These drawings keep going this way for about 3 more layers. I copied all of the C...
  3. In AutoCAD Architecture Options > Open and Save Tab, there are the External Reference (Xrefs) options where by default Demand load Xrefs is “Enabled with Copy”, Retain changes to Xref layers, Allow other users to Refedit current drawing are checked. May I enquire how is Xref handled internally...
  4. Hi, I am developing an simulation application, leveraging on using Space objects and applied additional Property Set Definitions for Space objects where I introduced a new Property "Value". I applied a display theme to my DWG, and based on the value of the Property, different colours wil be dis...
