Showing results for tags 'express tools'.
Autocad 2015 - Express Tools - Most work a few do not?
ILoveMadoka posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
(Autocad 2015) Express Tools is loaded, the Express Tools menu is displayed. 97% or more of the Express Tools work just fine. Tools -> System Variables (SYSVDLG) does not work (Unknown Command) Is there a way to manually fix this short of the uninstall/reinstall?- 10 replies
- express tools
- autocad
I am trying to convert text to mtext but the "txt2mtxt" command is not working. all the other express tools are working; this command shows up as unknown. I have searched for this command on the apploader and had no luck. How do I get this command to work?
- 1 reply
- txt2mtxt
- startup suite
Autocad 2015 Express Tools - Manually Loading?
ILoveMadoka posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
For some reason the Express Tools were not loaded when they installed Autocad 2015. I guess the checkbox was overlooked among the tons of other stuff loaded. In days of old you could copy the Express Tools folder, load the Express Tools Menu and "APPLOAD" the main file and you were good to go....- 13 replies
I am working in autocad for mac when I am not at work (dreadful program) and it's lackluster to say the least. Since there are no express tools, i can't FLATTEN the drawing. I have a bunch of objects on varying levels of the Z plane which is infuriating. it happened cause I got blocks from an outsid...
- 4 replies
- express tools
- cad for mac sucks
Acet- functions family... help me & help files
danie7LT posted a topic in AutoLISP, Visual LISP & DCL
Hi every one, For days I looked on the internet from detailed info to mere description of all the ACET-..... functions given by the express tools. I found a great excel file listing all of them (I think - see attached file: ACET-FUNCTIONS.xls) But nothing really tangible regarding how to use them...- 6 replies
- express tools
- commands
On the top in AutoCAD Architecture 2012 where the tabs are (Home, Insert, Annotate, Render, etc...) I am missing the one for Express Tools. When I right click on the area and under Show Tabs, there is not the option to tun it on or off, it isn't there at all. The computer next to mine which has th...
Needed a better alternative for Text Explode of Express tools
Ahankhah posted a topic in AutoLISP, Visual LISP & DCL
Hi every one, Althogh txtexp command of express tools, works fine in the lack of such internal command, but it has a bug. In some cases, it moves newly exploded text far away from the original location and changes the size of it. Is there any suggestion to correct this bug?- 14 replies
- text
- express tools
Hi to everybody, Is there a way to modify the tools blocks replace available in Autocad Express Tools ?. I try to explain better : - The express tools blocks replaces "all" blocks inside the dwg comparing the name. - I would like to change only selected ones ? Is there a way to have access to...
- 18 replies
- express tools
- blocks
