Showing results for tags 'export to pdf'.
    • export to pdf ×
  1. Hello everyoneI was plotting to pdf and everything was going perfect...suddenly this plotter started to produce .pc3 file instead of .pdf when I choose Adobe PDF as plotter. Anyone knows what's the problem? I'm using Autocad Map 3d 2020 &Adobe Acrobat DC
  2. I am trying to create a pdf file from a dwg file, using DWG True View 2013. I am NOT a CAD user, so all of the terms are new to me. I read that sometimes it's better to convert the DWG to DWF first and then convert it to PDF. So, I tried 'export' to DWF after trying 'export' to PDF. In both cases...
