Showing results for tags 'excel to autocad'.
    • excel to autocad ×
Found 8 results
  1. Hi Everyone, I'm new to AutoCAD lisp and have a couple of questions regarding GetExcel from the GetExcel.lsp functions. I am generating several tables using data from an excel spreadsheet. The spreadsheet contains several "Sheets" and a new table will be generated from each sheet. It will be unk...
  2. PeterPan9720
    Excel interface
    Please somebody can help me in a little issue ? I'm trying to have an excel interface in order to write some drawing blocks attribute excration. Here below code: Dim NUOVA_ISTANZA As Object Dim WRKB As Workbook ' Attribuzione della variabil...
  3. volkansahin
    Hello everybody,
    I need a complicated lisp for take information to attributes and choose blocks in cad file. So, I am working about Building Automation Systems, I am preparing "point list" and " connection diagram" for a project. My manager wants a lisp from me for choose blocks and insert data from excel point lis...
  4. I'm about to receive a bunch of borehole data for a bigger project with x,y coordinates in state plane for each hole and I believe it will be sent as an Excel file. I'd like to add a center-justified text consisting of the borehole name at the x,y coordinate where it should go so I can quickly chec...
  5. Dear smarties I read a few articles here and there regarding a way to generate multiple drawings from an excel file, but no one had explained step by step on how to do it. So, I am lost half way. I am very new to this kind of things, but I will try to follow, so please go slow on me. here is what...
  6. Hello, I have been trying to inport survey data that includes a descriptor into autocad from an excel file, with some prior forum posts on here I've been successful completing that. Now I am trying to change the layers as part of the data entry, the idea being that all my points are on the b...
  7. Hi all, I want to do something, and I don't know how. Here is explanation: I want to draw something in AutoCAD by blocks (which have attributes), and when I export attributes to excel (with 'data extraction') I would like if that data can be automatically linked with CAD attributes, so when I chang...
  8. 19cruthik68
    data link manager. how to
    Last month, I read in the forum about the data link manager and tried to do it as what the user told in the steps, and it works, now i am trying to do it again but it is not working (think i forgot some methods here) can anyone send me the link again or can anyone just please help me to do again abo...
