Showing results for tags 'excel in autocad'.
Hello, I am trying unsuccessfuly to switch layers from EXCEL. This is my code: Please advise Thanks Public Sub MISKO() Dim ACAD As AcadApplication On Error Resume Next Set ACAD = GetObject(, "AutoCAD.Application") Call ACAD_SELECT_LAYER("BIBI") End Sub Public Sub ACAD_SELECT_LAY...
Insert Excel Sheet into CAD File.
tipu_sultane posted a topic in AutoCAD Drawing Management & Output
How to insert the Excel File in CAD file. I am using AutoCAD 2012. I used io command and try to attach file by browse tab, but facing two problems. 1.) The attached file result display not full sheet i.e not all rows and columns that I want to display in CAD file. 2.) It only attaches the fi... -
need help, can any one tell me, how can i import the points (coordinates) from the excel to the autocad along the alignment. Excel contains the spacing of the points along the alignment. Is there any lisp for an ARRAY command with varrying spacing? thanks in advance.
I've to put some data as like table beside the figure. I've these data in a excel sheet. Can i import that sheet in CAD? or I need use table and re-type all data?
