Sorry, I'm newbie.
I just want to erase some object (viewport) in Specific Area at Several Layout. Every layout actually have the same position of object.
When this script work, I will make the (repeat n) version....
(defun c:xxxx ()
(setq p1 (getpoint "\np1: "))
(setq p2 (getpoint "\np2: "))
(setq seleksi (ssget "C" p1 p2))
(setvar 'ctab (car (layoutlist))) ; move to first layout
(command "erase" seleksi "")
(command "rectangle" p1 p2 "")
(setvar 'ctab (cadr (member (getvar 'ctab)(layoutlist)))) ; next layout
The problem is: for example, the active layout is the 3rd layout, and then I run this script.
It will only erase the object in the 3rd layout. But, it success to make rectangle in every layout...
I have no idea why this can happen. Thx in advance.
