Showing results for tags 'edit attribute'.
    • edit attribute ×
  1. Hi All, I want to make a lisp program to add prefix/suffix to all attributes of a selected block. Say, what I want to add is "(W1)". If the block has two attributes and if the attributes have their values 12134 and 23564, it should become 12134 (W1) and 23564 (W1) This process has to be looped s...
  2. Hi all, could you please give me a solution to update block attribute value in multiple layouts with out changing the existing values. eg: Tag DT3 Value "part-01" I need to edit the value as "MEP Part-01" The multiple layout have different numbers. So I need to add "MEP" to all layouts....
