Showing results for tags 'dynamic input'.
Hello everyone, I'm writing because I need to disable the dynamic input in AutoCAD. It's irritating to me, because I'm more used to a much older version of AutoCAD. I just found this forum while searching through the internet and this is my first post here. Upon searching through the inte...
- 11 replies
Help with dynamic door block
rajeev_acpl posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I had created a dynamic door block (my first one). As the block has door frame section on both ends, i need to place the linear distance parameter near the door hinge (and not on the basepoint for block insertion). This extends the door by 4" from the value of door opening i manually enter. Sup...- 9 replies
- dynamic input
- dynamic block
Hi, I work with dynamic input disabled but whenever I use measurement tools like distance or measure etc. they seem to 'return' only while the command is in use. It seems that they have their own setting. I've searched the online help files but can't find anything... Is this a bug or is ther...
