Showing results for tags 'dymamic block'.
    • dymamic block ×
Found 6 results
  1. Hi everybody, I defined two parameters inside "Dynamic Block" and called them "elements_hor_dist" and "elements_ver_dist". Now I want to use Array action (BACTION Array), but BACTION uses just parameters defined with BPARAMETER (i.e XY). Is it possible to put user defined parameters in de...
  2. Hi all, I defined a dynamic block containing some user defined parameters. When iserting attributes, I define one of parameters as a field. But after closing the Block Editor and inserting the block, It show just the word "UserVariable" instead of real value of the parameter. Does anyon...
  3. Hello, I have two reactor and two problems in callback functions. I have inserted same princ to be evident where is the error. Outside (from CallBack func reactors) they works properly. It seems that some LISP function are not compatibile to work in callback func (vlax-ename->vla-object,...
  4. I am attempting to create a Dynamic Block for electrical home runs that behaves similarly to the home runs my company uses in Revit. Essentially it is a Spline with (3) Control Vertices and an Arrowhead at opposite end from the Basepoint. I have created the Dynamic block to include the desired visib...
  5. Hi everyone, My intent in the dynamic block is to be able to show or be able to copy some elements within the dynamic block, please see attached dwg. The block represents a shear wall (structural element) that contains anchor bolts which are represented by the red dots. So, if I ha...
  6. Hello, I'm having a hard time finding the solution for my problem. I want to create a dynamic block in Autocad 2014 In this block I need to determine the intersection between 2 lines. In the sample you'll see my problem. I want to make A, B and C variables in my block. The angle on top...
