Showing results for tags 'dyanmic blocks'.
    • dyanmic blocks ×
  1. Hi, I am setting up a dynamic block with a few of the door types within the one block. Everything seems fine but when you switch between a few of the Flyout Options the panel size (which is scaled due to the arc) sometimes plays up. Try open the block; select "Hinged w_0 SIDELIGHT" say 780 and...
