Showing results for tags 'dwg to pdf conversion'.
    • dwg to pdf conversion ×
Found 4 results
  1. Hello I am using ACAD-2007, and am trying to plot my DWG as an "intelligent" PDF which preserves the drawing's layers, so that they can be switched on/off within the PDF using Adobe Acrobat 8 Professional's Layer View. Problem is, when I plot the file PDF, I open up Adobe's Layer View pane,...
  2. Hello everyone, I am having an issue with my print to PDF. When a drawing is printed to PDF, any notes on the drawing, some of the font comes out grey and is very hard to read. Does anyone have a solution to this? I'm using Autocad 2013. Cheers Sam
  3. Hi I need help My client needs an a3 drawing I drew converted into a PDF so he can print the PDF off to the correct scale. I created the pdf in autocad 2012 to A3 size and a scale of 1:1. I emailed the PDF to my client who now says that the PDF is not to the correct scale when he prints it, I i...
  4. NirantarVidyarthee
    Convert Drawing To pdf
    Is it possible to export a drawing to pdf without opening a drawing where AutoCAD is installed. I want to write my own code using AutoLISP or VB.Net (and not use any existing third party utility) because I have some specific additional requirements. Any guideline would be helpful. Is Obj...
