Showing results for tags 'dwg to pdf'.
    • dwg to pdf ×
Found 9 results
  1. Hey guys, Just a quick one - hopefully someone will be able to set me straight pretty easily. When I print PDFs using the AutoCAD PDF creator (DWG to PDF.pc3).... I get a pretty nasty representation of the text within the DWGs (see attached image). Does anyone know of a setting or a...
  2. Hi there, I'm trying to convert a few thousand files from dwg to pdf and I believe I'm on the right track but am a little stuck. I'm attempting to use DWG TrueView though I have limited access to AutoCAD for like template creation and such. I seem to have trouble getting some of them to plo...
  3. Hi, I need help. My AutoLISP works well in DWG To PDF but it comes out 1 file per 1 DWG. I want it to be the only PDF file. Can somebody help me with something? (I can't use third party programs) Thank you for your help. The examples are in my attachments. My_Plot.LSP Test.dwg
  4. Hi guys, This one has been giving me some headache. Could anyone of you point me into the right direction, I'd be most thankful. Software used: ZWCAD2014 on a Windows 10 machines. For those who may not know about ZWCAD: it is an actual and legal clone of AutoCAD 2012 official...
  5. naren
    Dwg to pdf
    hi guys, I have found a desired lisp routine to convert DWG TO PDF after long googling and made little changes to suit my requirement. Here problem is this routine converts each DWG at a time but I have to convert around 100 dwgs to pdf. somebody can help me to convert this routine to proceed as...
  6. I keep needing to manually change the plotter settings for many Layouts in the files that I'm receiving (from many different consultants) to "DWG to PDF" and then clicking on "Display plot styles." Is there a streamlined way to do this besides clicking on each Layout individually, right-clicking...
  7. Hello, I'm using Autocad LT2012 and I have a problem with the "print to PDF" from the Sheet Set Manager. The layouts are all set to "publish to a plotter" with the Layout option (not Window, Extent, etc.). When I send the print to the plotter from the SSM, they print fine. If I send them to PDF,...
  8. I have a new tip about batch converting cad files to any image type. Popular image viewer IrfanView now supports dxf format for free (new freeware dxf plugin in irfanview 4.35). I use irfanview for a long time cause it has great batch-process features. You can convert hundreds of your cad drawing fi...
  9. Is there a way to have the AutoCAD "Quick Properties" pop up functionality be transferred over after the dwg is converted into pdf or dwf? I want to avoid clutter in the dwg file but would like to have an ability for my field crew to either hover over or click the blocks or AutoCAD objects in th...
