Showing results for tags 'dwg files'.
    • dwg files ×
  1. Hi Guys, Someone knows a Lisp used to replace a internal block(s) of a folder with dwg many files. Eg: The specific folder has a "n" files with A3 formats blocks using the same attributes and tags, so, if it's necessary do a correction in a little detail in this format, it's necessary to rep...
