Showing results for tags 'draw order'.
    • draw order ×
Found 7 results
  1. This is related to command LayerOrder or AecLayerOrder in AutoCAD Architecture 2015. This command lets user specify the order in which layers are displayed in the drawing. I'm trying to modify the order by program, but can't find where this list is stored. It has something to do with a dictionar...
  2. Hello there! I need to make a small sub which aims putting all modelspace hatch objects to bottom in draw order. I've debugged the code below, but the line in red never works. Now I'm trapped in here. Please someone help me out? Thanks a million. Sub hatch_to_back() Dim eDictionary As ObjectDi...
  3. Apparently I have overloaded AutoCAD's little mind. I needed a way to cover the background of a bubble note, which is a multileader with the standard circle for content. First I tried Wipeout, but it kept turning out dark in PDFs. Then I tried a solid hatch with override color 255. Obviously I want...
  4. Hi, I'm new and self taught on cad (so sorry if i appear dumb) I've used cad now in a basic 2d architectural sense now for 10 years, through various versions. I have recently dropped back to a 2007 from 2008 (changed jobs) and for some reason the draw order is all messed up i noticed thi...
  5. Hi all first of all thanks to everyone for all the help in the past, a really cool community here, hopefully one day i have the knowlede to return the favour. maybe i could shout a six pack of ausie beer some time. I am working on a road design with a whole set of drawings that have about 10 -1...
  6. i am using autocad 2009. draw order options like 'send to back' or 'bring to front' , for solid hatch, are not working in my drawing.. previously they used to work. bt nw they r nt working in that same file. tried all possible ways..
  7. Is there anyway that I can assign a layer to be always in the front/on top of all other layers in draw order?
