Showing results for tags 'drafting settings'.
    • drafting settings ×
  1. I'm using ACad MEP 2010 and attempting to change Object Snap settings via the Drafting Settings. When I select settings I get: Which seems corrupted. If I click on, say, Tangent I get: Can this be fixed? Thanks for your help.
  2. Where do I need to go to disable this option, I've had to recently reinstalled AutoCAD and this small setting is driving me nuts. I use the MeasureGeom command about 250 times a day and with the setting it is in now, this will add a click to my work.
