Hi.
While trying to do a dynamic block of a timber flush door for a 150 and 200 mm wall, I am having a problem with the arc representing the door swing.
When door is stretched, there is a gap appearing between the door panel and the arc and same also with the door frame.  The more the door width increases, the more the gap.  Trying to add parameter deform both door panel and the door frame at connection.
Your help and input are greatly welcomed. Thanks.
FlushDoor DynamicBlock.dwg
