Showing results for tags 'display error'.
    • display error ×
  1. mhupp
    Highlighting with ssget
    When I am selecting things with ssget they don't show up as highlighted until i zoom in and out with the mouse wheel. look though the setting and have auto regen on. Selecting things outside of a command auto highlights them.
  2. Hi all I'm working on some information that I have imported into LT 2017 from 12D survey software. Basically I have a road string (polyline made up of arcs) and I'm tidying it up. All I have done to this string is break it and change the layer it is on. When I go into Paper space and look...
  3. Hello! I've run into this a couple times lately. Text or mtext will become a squiggle. This is usually in a block, maybe even within a block in an xref. Hopefully the image shows below.
