Showing results for tags 'dimensioning problem'.
    • dimensioning problem ×
Found 5 results
  1. theinventor87
    Dimensioning Problem
    I am learning Autodesk Inventor and am having trouble adding a certain dimension to a slot to a product I am embedding into a 2D sketch. Attached is a screenshot that portrays the issue I am facing. Thank you in advance for your assistance.
  2. So i have this block that has dimensions within it, and everything looks neat. In editing the block, I add more dimensions and the size is appropriate. However, in dimensioning outside of the block, the figures come out very large. Why is that? Dimension query.dwg
  3. Hi this is my first post and have been using AutoCAD since R14 but actually just noticed this. All layers in there are as exactly as they should be expect a few lines which are on 'LAYER 0' So I've exported the drawing by printing from DWG to PDF. I've tried freezing the Dimensions but I hav...
  4. When dimensionning linear dims using leaders, I can't get the dimtxt to slide from one side of the dim line to the other. The dimtxt only switches side if I place the dimtxt on top or below the dim line. Very weird. Can you help on how to work around this. Please see flickr picture link for a b...
  5. A coworker and I are having the same problem with dimensions. For example, we have a polyline that has been dimensioned and then we will either need to trim or break a small portion out. When we trim or break the line the dimensions on that line fly all over the place so we end up needed to re-dim...
