Showing results for tags 'dimension style'.
    • dimension style ×
Found 8 results
  1. Dear All, Im Trying Create Layer with Dimension Style and selected dimension change layer name but not working properly. plase help me completed code . (defun c:Test-11 () (setvar "cmdecho" 0) (setvar "CELTSCALE" 3) ;;------------------------------------ Create Layer --------------...
  2. Hello everybody, I've created a macro for creating different dimension styles for different scales. We are using these dimension styles in our company. It works well if I use it in a new, empty drawing. But if I use it in an excisting drawing with a dimension style with the same name, I have go...
  3. Is there a way to create a continuous dimension line that uses running dimensions instead individual segments? I know that you can do baseline measurement but I received a request to have the dimensions look like a continuous dimension line, but be running dimensions. I'm aware of UCS -> c...
  4. psuengineer84
    Modifying Dimension Styles
    I work for a firm that has horrible drafting conventions - i.e. exploded dimensions, etc. So, I am *trying* to match their crappy hand-drawn dimension style with a standard style. My question is how to remove the lines perpendicular to the extension lines that extend outside of the arrows w...
  5. Having drawn this spacer for the tutorial I am following, I decided to add the dimensions. The dimension shown here is 200mm but you wouldn't know that. How do I set the dimensions so I can see the arrowheads and read the text?
  6. When drawing in .stb-file (with layer dependent plot style, plotting in monochrome) and when Dimension Text Style is set to Romans (must not be changed), then how to change line weight of Lines and Text separately? Please help. Thanks.
  7. This used to work, then my computer dies and AutoCad was reinstalled. I am trying to dimension some cut-outs in a 19" rack panel. I can dimension them, it shows the correct dimensions but then when I hit enter it wont save the dimensions. I've gone into DIMSTYLE and everything looks fine but I cant...
  8. I'm working on a drawing that was converted into cad and it seems like every dimension has its own style. When I copy use the move comand or try to change the dimension the text changes from being above the dimension line to centered and the text gets closer together horizontally. When I compare a c...
