Showing results for tags 'dimension lines'.
    • dimension lines ×
  1. In the attached drawing, one of the dimension lines is strangely bigger than others. I tried to use match properties or alter the text size in dimension properties, but neither worked. How can I correct it?
  2. Can i change the length of the dimension line 'extension' when my dimension text placement is beside the dimension line (see attached image)?
  3. Is there a way to create a continuous dimension line that uses running dimensions instead individual segments? I know that you can do baseline measurement but I received a request to have the dimensions look like a continuous dimension line, but be running dimensions. I'm aware of UCS -> c...
