Showing results for tags 'dimension error'.
    • dimension error ×
  1. Dear all, i have a problem, i want summing the actual dimension. example:dimension shows 22 27/32" but decimal shows 22.83333. not show original 22.84375 its various. how to i find this error.or how rectify this error. and i sum this 5 intermediate is 22 27/32", its comes error 1/32" or 1/16...
  2. I have made an assembly using skeleton modeling. Everything looks OK in the assembly. When I want to dimension the part in a drawing, some dimensions don't attach to the part.02_Bunker_Pl02.dwg 02_Bunker_skeleton.ipt 02_Bunker_Pl02.ipt
  3. We are getting this error and can't figure out how. I am drawing using construction lines, inputing exact lenghts. so on. Normally dimensions are rounded up so it wouldn't matter. I have a client that requires dimensions to be exact. I set the dimension style Alternate units on decimal max precision...
