Showing results for tags 'dialogue box'.
    • dialogue box ×
Found 6 results
  1. Hey everyone! It's been a minute. Quick one here... Is there any way to lock the location of the Text Formatting box that pops up while editing text in C3D 2014? I'd prefer it to pop up over my Ribbon, rather than in the actual Drawing Window. See below for clarification. I thought...
  2. I've been using Autocad 2017 hobbyist/student version for a few months, all was going well until I wanted to play with materials. I downloaded medium resolution materials, installed service pack 1, went well. Got materials to work. If I tried hitting things in dialog box without waiting a few second...
  3. Hey guys, Just this morning I had a thought of creating a DWT template containing a bunch of hyperlinks to our job/model directory. The philosophy is that you would start your ACAD session and be presented with a series of links (prepared in the DWT) to various job/drawing directories and model...
  4. Hey guys, Not really an AutoCAD question here... But I would like to post just in case someone is familiar with this particular problem I am having. Just the other day I switched from Windows XP, AutoCAD 2010 (with ProSteel) to Windows 7 (64bit), AutoCAD 2012 (with same version of ProSteel)....
  5. mr cadman guiff
    Saving files - AutoCAD 2011
    I'm using AutoCAD 2011. When I click on 'File' and then 'Save As', instead of a dialogue box on screen, I get, on the command line, the following: 'Enter File Format R14 (LT98 & LT97/2000/...........up to 2010) How can I get rid of this of the command line and get the dialogue box back? Thanks...
  6. Hello all, i have had this problem for some time now, but im just now getting time to post it. Basically the problem i have is that certain AutoCAD commands, not all, that require a dialogue box do not work, i.e insert, drafting settings, linetype settings, etc. When i invoke the command AutoCAD j...
