Showing results for tags 'dialog box'.
Hi all, this is a cutout of a dcl file with toggle boxes. How can I predefine the selection "lathe machine"? (So that this checkbox is always checked). Currently, the selection that was previously selected is always applied. With radio-buttons it works with "value=1", but not in this case....
Hello, I am working with C3D 2018. All of the dialog boxes that permit input are behaving poorly. If I highlight a field I typically do not have time to enter the data before the pulldown closes or the box stops allowing input. Another example would be if I was trying to change an alignment s...
- 1 reply
- input
- dialog box
Insert New RevBlock above existing RevBlock in Layout tabs
Fett2oo5 posted a topic in AutoLISP, Visual LISP & DCL
We are looking for a way to revise multiple layout tabs (single .dwg file) at one time. We design our product in 2D in one .dwg file. We use the layout tabs for multiple views of the objects that are in modelspace, (each layout tab has the project titleblock on it, but each layout tab has its o...- 18 replies
- layout tab
- insert block
Running a function from DCL button causes crash
jbennett134 posted a topic in AutoLISP, Visual LISP & DCL
*Disclaimer* I'm not sure where this code came from, it's probably hashed together from several forum posts. I'm working on revising this layer renamer that didn't quite work. I've got the dialog box setup and working fine. I've got the layer renaming functions setup and working fine. The pro...- 11 replies
- dialog box
- crash
Hello all, I've tried to get some help with this in the past and haven't been able to achieve what I'm after. I think overcomplicated it before. Can you manipulate a dialog box (proper term may be user interface?) with lisp? I have custom commands that bring up a dialog box with various options...
Hi everybody! I'm trying to create dialog box for creating new layer, I googled everything I could remember, but I can't find anything. Set newLayer = ThisDrawing.Layers.Add("NameOfNewLayer") should create new layer, but how to define color or weight or type of lines? P.S. I'm using...
I was on my previous employers computer with auttocad (he says)2009 (it says 2007). I was helping him make a few tweaks. In short I made his SAVEAS dialog box dissapear. Now when hitting "saveas" it shows in the comand line- no popup dialog box. Please help me fix this error (and get me out of hot w...
- 1 reply
- pop up
- dialog box
new to the dialog boxes. Been trying a routine and failing. Can't figure out why. The routine opens the dialog, which should allow me to pick 1 out of 3 blocks to instert and to define the scale of the block, text to be inputed, and the text style to be used. The idea was planed to first define def...
- 12 replies
- dialog box
- autocad lock up
Hello All, I tried to solve a problem lisp and DCL but it is clear that I have a lot to learn. With lisp's trying to insert text in Autocad list opens (see DCL). Any help is welcome. Dialog Text.zip
- 1 reply
- insert
- dialog box
I work for a manufacturing company. We use AutoCad to do our estimates. We take custom block and overlay them on tiff backgrounds of the architectural plans. Then we export the block info into spreadsheets to complete our takeoffs. As of now we use dynamic properties and attributes in the blocks to...
Okay so two questions both relating to text in a multileader. 1) I have written a lisp that sets layer, creates a revcloud but when it gets the point at which it generates an mleader, I run into problems. Basically it draws the leader then ask me for the text in the command window. But soon as...
- 14 replies
- lisp
- dialog box
I am currently using Autocad Map 3D 2010, which uses alot of the same commands as AutoCad 2010. Atleast that is what i have been figuring out since i cannot find any help really online with trying to learn this version,(Map 3D), so i have just been learning the regular Autocad 2010. But that is anot...
