Showing results for tags 'design centre'.
    • design centre ×
  1. I am trying to adjust a block that I got from the AutoCAD Design Centre to my specific length but it would only grow / scale to its preset constraint measurements, EXAMPLE I want 2000 units but it has options of 1008 and 2016 units. Will Block Editor help me, maybe? AutoCAD 2015
  2. Hello, this is my first post so go easy on me! When working with other drawings I've got into the habit of dropping in my layout using the design centre rather than copying the whole drawing into my template setup. Most of the time this works fine but every now and then my layout will be massively...
