Showing results for tags 'design center'.
    • design center ×
Found 6 results
  1. We have changed the color, line weight and description of specific layers. We used to use Layer state to update the layers, now we use the design center. Changes made in Example 1. Example 2 has the wrong layers - so Design center is open, layers from Example 1 are dragged and dropped into Exam...
  2. How do I open the Design Centre and see "blocks" that are bound xref with $0$ in the name, unless the bindtype is set to insert.
  3. I have 10 separate drawing files that I want to combine into one drawing and I want each drawing to be on a separate layout. I want to end up with one drawing with 10 layout tabs each containing the graphics from one drawing. Each drawing has one layout with the graphics on it. No fancy paper sp...
  4. I've tried dragging layers across drawings using the design center interface, but what I've noticed is that while the layer in question gets copied over, the layer is empty. The objects within the layer do not get copied over. How do I copy objects AND layers that I've selected across drawings using...
  5. hi, i am using cad designcenter blocks for bolt and nuts what happened while dragging (whether i have done it or not) the nut size is 4 times bigger is coming i gone checked in the source file of design center it is ok there but when i drag i from the paletter it shows size more and the same compone...
  6. Hello; I am having trouble with blocks that I am not using anymore in my file. I have inserted blocks from other files using design center, dragging it to my new file. In my new file I exploded the blocks. It doesn´t let me purge it, and it still appears in the design center of my new file, event...
