Showing results for tags 'deleting objects'.
  1. Hello Everyone, We are looking for a lisp that will delete objects on every layout in a drawing. I have seen a lisp that will delete objects of the same type and layer on every layout, but unfortunately that doesn't give us enough descriptiveness to only delete the objects we need to delete. The location of the objects we want to delete will be the same on every layout, so ideally the lisp will be able to take a selection window on one layout, and delete all the objects within that window location on every layout. If it is easier for coding purposes, we could even draw a box with lines/polylines on one layout and use that to define the selection window for all the other layouts, and then just delete the box at the end from the one layout. If anyone has any ideas, or if any more information would be helpful, please let me know! Thank you all, - Noah
